Highest lift cam on 96 heads
Old Feb 25, 2003 | 04:22 PM
mtxpert's Avatar
What is the highest lift cam you can use with 96 heads?
Also are the studs safe to use 1.6 RR's for a high lift cam.
Thanks!
Mike
Old Feb 26, 2003 | 01:08 AM
cef97ws6's Avatar
Mike your question is a bit vaque on what your true intentions are. But provided you have the proper springs the main limitation to lift would be piston to valve clearance. As far as 1.6 rockers go again depending on the final lift and necessary spring rate a stud girdle might be necessary with extremely high spring pressures. A little more info is needed for a more direct answer.
rideordie
Nov 5, 2019 04:52 PM
StansZ28
Feb 19, 2015 07:39 AM
Roadie
Feb 16, 2015 10:34 AM
jmzlt1
Mar 13, 2003 07:26 AM
