Higher rpm missed
Old Apr 2, 2007 | 10:01 AM
somebody's Avatar
Higher rpm missed
Ok before everyone says use a search i did and can not get one single answer. And everything they are suggesting I have done. My car is a 95 lt1 and it seems to die out around 4000 and higher. Also in the lower rpms if I give it alot of gas it has some hesitation to it. I have replaced the coil the wires and plugs. Also I have did all the egr stuff with all new parts and lines. The only thing I havent replaced is the opti. My car has 86000 miles and Iam worried that it might be starting to go. I have another but dont want to put it on if the problem is something else and easier. lol. Any suggestion would be great.
-Thanks Brandon
Old Apr 2, 2007 | 10:20 AM
doug1105's Avatar
Check the Opti harness yet?
Old Apr 2, 2007 | 03:13 PM
Bandit 1's Avatar
might be a fuel problem, if not maybe some screws cam loose with the opti
rideordie
Nov 5, 2019 04:52 PM
CodieG95
May 28, 2015 03:59 PM
BLK1997Z28
May 7, 2015 03:01 PM
DetroitZ28
Feb 13, 2015 07:33 AM
kev93z28
Aug 19, 2002 12:48 AM
