High volume water pump
Has anyone ever run one of these high volume GM performance water pumps? I need a new one and I don't want to go electric but if I can get a higher volume pump why not? I found this one at summitracing.com for $195.95. Part # is NAL-12527741. Let me know if anyone is running this and how they like it? Thanks
Thanks for your responses guys I realize that the part # is the same as the stock pump but that is without the prefix. Before you get too bent out of shape I have worked on airplanes for 16 years and you would be amazed at how many parts I have ordered thast the prefix or suffix is slightly different and it is almost the same part but it is for the right or left wing or whatever subtle difference. What I am really looking for is anyone that is running that pump. Again I appreciate the responses.
