High volume water pump
Old Apr 16, 2007 | 07:52 PM
AXEMAN's Avatar
Has anyone ever run one of these high volume GM performance water pumps? I need a new one and I don't want to go electric but if I can get a higher volume pump why not? I found this one at summitracing.com for $195.95. Part # is NAL-12527741. Let me know if anyone is running this and how they like it? Thanks
Old Apr 16, 2007 | 08:35 PM
AXEMAN's Avatar
anyone
Old Apr 16, 2007 | 08:55 PM
96capricemgr's Avatar
Like I said LOOK IT UP that is a STOCK pump, don't believe me check and see what PN the dealer gives you for a stock pump.
Old Apr 16, 2007 | 08:59 PM
12527741 is the GM part number for the normal pump used on f-body LT1s.
Old Apr 17, 2007 | 09:40 PM
AXEMAN's Avatar
Thanks for your responses guys I realize that the part # is the same as the stock pump but that is without the prefix. Before you get too bent out of shape I have worked on airplanes for 16 years and you would be amazed at how many parts I have ordered thast the prefix or suffix is slightly different and it is almost the same part but it is for the right or left wing or whatever subtle difference. What I am really looking for is anyone that is running that pump. Again I appreciate the responses.
Old Apr 17, 2007 | 09:58 PM
The prefix is a manufacturer code Summit uses all the GM parts they sell use that prefix.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Queens94z28
Dec 20, 2014 09:11 PM
