high rpm stumble/ injector question
Old Jul 17, 2011 | 09:28 PM
Dan93z28's Avatar
for the past couple weeks the car has had a stumble/miss at high rpm (4500-5800) only at WOT it is pretty consistent and has happened more than half of the time i go into that rpm range.I believe it is the injectors as I've replaced most of the ignition with the exclusion of the opti.
My question being that i plan to install a small cam and mild heads this winter(probably LE1 with his 218/224 cam) will injectors with stock flow(its a 93) be enough for this set up or should i be looking for something bigger? 30's maybe?
thanks for your time, Dan
Old Jul 17, 2011 | 10:14 PM
Re: high rpm stumble/ injector question
Properly set up, and with the correct supporting mods, that should be over 400HP at the flywheel. You need 28's for 400HP. I'd think a set of 32's would allow a bit of room for better than 400HP results, and a little bit of future growth.
AdsoYo
May 2, 2018 03:21 AM
LT14LIFE
Feb 9, 2015 09:35 PM
97SSdude
Dec 31, 2014 07:43 PM
nophix
Nov 30, 2014 10:26 PM
