High RPM miss...only when hot
Bandit,
90% of my posts are helping other people. I read tremendously before I ever ask a question. Sorry you take my frustration as "****ty attitued". It is trying to get to a solution.
Do you have something to add to the situation? I am very willing to hear it.
Ben
Ben
I am willing to consider this. However, the problem is so specific to temperature, I would consider it less likely. The reason being is that variances in air flow will affect the final temps wiring will see outside of the block but electrical, etc. attached to the block will be more likely to be affected on a more specific basis.
I am wondering if this is a closed loop/open loop problem as opposed to a specifically temperature related problem, unless that is something you have already looked into where you've experienced the problem in both open and closed loop.
also is this an issue that has existed since the completion of the setup or something that developed over time?
Is it possible you have a fuel line too close to the exhaust, and the engine/exhaust heat is causing the fuel in the line to vaporize? While fuel flow/pressure isn't directly related to engine coolant temp, the longer the fuel pump runs, the hotter is may be getting. Couple hot fuel, brief pressure losses, with a line too close to the hot exhuast and it may be vapor bubbles. The brief pressure losses might not show up as visible drops on the fuel pressure gauge.
"I think" this has always been here but not sure since I have been working on so many problems with the car for the last 2 years. This is like the final issue that must be resolved.
Yes the exhaust is within about 6 inches of the fuel lines for a foot or more. It will be easy for me to wrap the fuel lines in high temp tape and try this scenario.
My first thought was ICM taking heat from the heads. My noob suggestion would be the washer trick, and zip-ties galore.
The fuel vaporization theory seems plausable. I've seen it happen to Beach Bonanza aircraft engines during the 100'+ weather in TX. Even with 100LL Avgas...
Thanks for trying to fill in some knowledge gaps. Next was actually to move the ICM and coil to the fender to totally keep it away from the heat but something tells me after 3 ICM's and NO change in status of the problem it is not the ICM.
Engine harness routing is the same as a stock F-body. All other wiring has been changed in the last month that would impact ignition and no change to the condition. Oh yeah...hours upon hours of google and some interesting things come up to try but no solution.
Based on the discussion here, I come to 4 possibilities:
MUST USE AC Delco opti only (maybe the multiple Autozone remans just can't do it)
OEM Engine harness wiring from PCM to ICM is bad
OEM engine harness wiring from Opti harness to PCM is bad
Heating up fuel from exhause before it enters rails
You are welcome to throw others into the mix.
Try the advanced boolean search parameters on google. Copy the following to google exactly as appears here with all punctuation. It should yield more relevant results.
LT1 "high rpm" (miss OR skip OR misfire OR stumble OR hesitation) "when (hot OR warm)"
Just throwing this out there...
Is it a hydraulic, or mechanical cam? Years back I saw a guy adjust his solid lifters a hair too tight. Car would fire up, but as soon as it came up to operating temp the valve train expansion would hold a few valves open....just very slightly, causing a miss. Slight miss on some cyls, bigger miss on others. As soon as it cooled, the problem went away.
Figured you might have swapped in a solid roller, based on your other mods. Good luck. And yes, from what I'm learning, stay away from AutoZone Optis...and Acell...and ANY aftermarket ones on eBay.
