high rpm lost spark. bad opti?
Old Jan 1, 2004 | 07:50 AM
696redZ-28's Avatar
well I was showing off a little yesterday, car was cold right out of garage.I was doing a 1st gear burn out untill enging came to rev limiter about 6000 rpm and as i went to shift the car died. How embarassing! Well i have no spark to plugs. Any thing ealse I can check before doing my first opti? car has 40,000 miles taylor otvc wires, reprogrammed ecm which raised max rpm some.
i also looked in vave cover while cranking and the rockers are moving. thanks for any help!
Old Jan 1, 2004 | 11:51 AM
ChickenScreamer94's Avatar
first of all, you should never run a cold engine hard. Oil is still very thick and cant flow very easily. Basically, you are starving some part of your motor for oil at that high of a RPM. Enough guilt trip .
This may be an opti. Since your rocker are moving you can rule out timing chain. So all that is left to check is about a million things...
Can you hear the fuel pump prime? 40K miles on car or wires? I am leaning towards coil or opti sorry. i have read on a few other boards of opti's going out all together at high rpm, usually above 5,5K.
Old Jan 1, 2004 | 12:48 PM
696redZ-28's Avatar
I had a chance to check coil is working but no spark out of opti. I can hear sparks when I hook wire to the opti but can not see any. fuel pump is working. I'm pretty sure something in opti came apart well I,m not near a lift so in the driveway will have to do at least the weather is great!
motor and opti 40k. plugs wires 1k miles
AlaskaZ28
Dec 16, 2014 07:24 PM
mattszm6
Dec 14, 2014 07:09 AM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
nophix
Nov 30, 2014 10:26 PM
