High RPM Backfire When Hot
My car (94 T/A, A-4, all stock) runs great when it's cool. But once up to normal operating temp (220 deg), it backfires through the exhaust at higher RPM. It's fine up to about 5000 RPM, but right before the 2-3 upshift, it sputters and backfires. Once the shift is made and the RPMs are down, it runs great.
Any suggestions?
Thanks,
Finn
Any suggestions?
Thanks,
Finn
Had the same problem 2 years ago, high RPM backfire, lived with it for a while.. told myself just dont run it high RPM but it finally started to bother me, why own this car if you cant use all of its performance potential. Car wasnt setting any codes, fuel pressure was fine, drove it with fuel pressure gage connected. Plug wires were only 10k miles old. Replaced opti, no help. Ran car at night to look for sparks from plug wires none... Drove down the highway at 60 mph in 6th gear and accelerated in 6th gear trying to load up engine to make it miss fire, ran fine.. At this point was totally confused . Went ahead and bought new plug wires even though wires on car pretty new. Installed new wires, problem fixed.... thats my story. Your case may be as simple as a coil wire, a coil, or plug wires. Good luck.
Thanks to all for the input.
The Opti is fairly new (for whatever that's worth) and I've done the washer thingy. Don't know when car last had the plugs and / or wires changed. I've been putting that off, but I guess it's time...
Thanks again.
Finn
Edit: Oh yeah, I got the 160 deg therm but haven't rigged up a fan switch yet.
Thanks again.
Finn
This trick with the washer...
http://shbox.com/1/4th_gen_tech2.html#ICM_cooling
It doesn't seem to have helped me, but it probably didn't hurt and the price was right.
Finn
Finn
Drtryder
Apr 22, 2015 04:17 PM
And put a damn 160º thermo in that. My car never reaches 220º.
