high oil pressure and rpms.??
Old Sep 1, 2003 | 07:58 PM
97BBlackZ's Avatar
When ever i start the car up the oil pressure is higher then it normally is.. Its like just over 40 at start and sometimes its almost half way to the next line.. it used to be at the 1st quorter mark and when i accelarate (depending on how fast) it would go up to about 40 and drop back down..
It will also give off like a vibration dou to the high oil pressure im thinking.
The oil pressure will only go back down to normal once then engine has reached about normal temps.
the engines idle rpms are also up. around 1k or 1.2K and those go down to when the car reachs normal temp.
So what could be the problem????
Old Sep 1, 2003 | 08:10 PM
Got-LT1's Avatar
could just be the car warming up, mine did something like it every now and then.
Old Sep 1, 2003 | 08:32 PM
94formulabz's Avatar
Re: high oil pressure and rpms.??
[i]
Thanks [/B]
The problem is that you think something is wrong and it's not
Oil is thicker until it's warmed up fully, thats why yours and everyone elses oil pressure is higher after cold start.
The pcm sets the idle higher until it's warm too.
Brent
Old Sep 9, 2003 | 12:31 AM
97BBlackZ's Avatar
o well that was the reason i asked.. it used to NEVER do this at all and the oil pressure was normal it will also give off this weird vibration that doesn't feel right.. like there is something wrong.
i did start it up one time.. (after the car has been sitting for awhile and the temp was all the way down) and it started up like normal... but i think i felt the brakes were a lil different..
Could there also be a problem cuz this has started after i like slamed on my brakes and the car kinda slid so could there be something to do with the brakes? and not to mention that its like 90-100 degrees outside..
Old Sep 17, 2003 | 10:55 PM
notstock4long's Avatar
Wow, my oil pressure is always up past the 3/4 mark until it gets all the way warmed up, then it goes down to about 40. I always thought I pressure was good. Am I wrong???
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
