high mileage questions!? advice plz
Old Jan 30, 2007 | 12:29 PM
zstangboi's Avatar
so my 94 z28 has 175000 miles on it, im sure it needs to be rebuilt, but dont have the money for that, i tuned it up and it runs decent. would it be a good idea to plug the EGR and maybe plug the things on the exhaust manifold that look ugly, because it doesnt have the cat anymore, plus take off the air pump, what else should i do? and could i have reasons why or why not to do so
Old Jan 30, 2007 | 12:47 PM
BUBBA's Avatar
Personally, I wouldn't mess with it at all. If it ain't broke....
Old Jan 30, 2007 | 12:53 PM
2000GTP's Avatar
You don't stand much to gain from hacking off the emissions equipment other then cleaning up the engine bay. If that is your goal, then go for it. You mention your car is running decent, is there a driveability issue? If so, I would investigate and fix that before even attempting any modifications.
Old Jan 30, 2007 | 12:57 PM
zstangboi's Avatar
just a miss or stumble during load between 1500 and 2500 rpm, i hear its the bosche plugs i put in, everyhing ignition wise has been replaced new, i guess i need to go with ac delcos
Old Jan 30, 2007 | 12:58 PM
2000GTP's Avatar
I've heard of Bosch plugs being problematic, that could be the result of your low rpm miss. I would stick with some Delcos or NGKs.
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Dec 1, 2014 08:08 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
