high mileage LT1
Old May 2, 2003 | 04:12 PM
slowpoke96z28's Avatar
high mileage LT1
what are some things i need to look at before i begin modify a LT1 with approximately 180k miles on it. it has new plugs, wires. and optispark. it pulls 20" of vacuum at idle, so the compression seems to be good. what do you guys think?
Old May 2, 2003 | 04:17 PM
zlightning's Avatar
I'd say leaks, wierd vibrations, suspension bushings. Trans mount.
Old May 2, 2003 | 04:20 PM
dnz28's Avatar
as long as its good fix the plastic stuff under the hood like sensors because heat kills them. Then go out and do a smokey burn out.
Old May 2, 2003 | 04:52 PM
BOWTYDE's Avatar
Just check it for leaks. It won't really start breaking until you do the mods.
HectorM52
Jun 23, 2016 08:42 PM
Jason Short
Jan 19, 2015 06:34 PM
Dec 1, 2014 08:08 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
