high idle, can fix by blippin throttle? im stumped
when i drive around and give it any gas 9 times out of 10 when i let off the idle stays around 1800-2000. if i let off the gas it will keep pullin when it gets to that rpm. if i push in the clutch it will stay there.
if i blip the throttle fast it will idle back down. and seems like when i give it gas the next time it seemslike it is kinda hung. could there be something keeping it from going closed all the way. ( i have cleaned the **** out of it with b12. spraying while its runnin) i dont know what it is.
anyone know of this same problem? seems better since i cleaned it and the MAF. but still does it. before i cleaned it it wouldnt idle down hardly at all.
Re: high idle, can fix by blippin throttle? im stumped
I dont know for sure, but my guess is maybe the IAC? http://shbox.com/1/iac2.jpg and
http://shbox.com/1/4th_gen_tech2.html#iac_reset
Also make sure that your cable isn't getting hung up on something, I had that issue at first when my monoblade went on and it turned out that the cable was getting stuck on some other wiring in the area. I have since rearranged things up there and the problem disappeared.
