high idle
Old Jan 19, 2008 | 02:23 AM
Daniel6718's Avatar
high idle
guess my old thread go too long for anyone to help me out so here
ill re explain since i just drove it....start cold it goes to 1500 then goes to 16 17 1800 the stays...i drive down the street and inbetween shifts it tries to rev up higher...got to 50mph pushed in the clutch out it in neutral and it goes to 16-17-1800 and stays....
after it gets a little warm i can do the same thing, push in clutch it surges going from 1500(50mph) to 1000 to 1400 to 1000 to 1400 until i stop it goes to 1200 then 1150 then 1100 then 1000 slowly
mods are longtubes k and n cold air...poly motor and trans mounts...bmr subframes...lca/relos thats it....nothin on the motor tranny or car is older than 9k miles...
put it on a smoke machine and made sure it had no bad leaks and it had a small leak from the vac hose going into the opti an comming out of the oil filler neck???????? is that right???
fpr vac line is fine fpr doesnt leak gas...vac canister vac line and check valve to the a/c controls are fine
checked vacume and its 18-20 at idle
iac was around 29 at idle...never went below 25 or above 35...perfectly normal
o2 were both boucing around like normal...neither was lazy...blm i think were around 120....
weird though the desired idle was 800..but on the scanner it said it was idleing between 920-960
the gauge matched the engine temp on the scanner...it read 185 at idle...with one fan on
any other ideas....sometimes you can pump the brakes and it will idle up...
i replaced the iac with another i had sitting around and still the same problem
the cruise cable has plenty of slack...the brake booster doesnt leak...i guess i need to drive it again and see what the iac is doing when it idles up real high...and if that dont work back onto the smoke machine...ive changed pcv valves and iac motors throttle bodys cant think of anything else
Old Jan 19, 2008 | 08:04 AM
Guest47904's Avatar
Guest
Are you sure the throttle blades aren't hanging up.
If there aren't any codes set (whether or not the SES is set) then the only thing I can think of to look at is the throttle blades.
Old Jan 19, 2008 | 10:43 AM
Daniel6718's Avatar
no codes...i would have though it wouldent be that since ive had 2 differant t/b on it...i adjusted the other one all the way closed by the screw and didnt change any....
Old Jan 19, 2008 | 12:20 PM
Guest47904's Avatar
Guest
How about trying to unplug the IAC then very gently pull the pintle out further and reinstall it so hopefully it completely closes off the idle circuit and see what it does at idle. Would answer if air is getting in somewhere else.
Old Jan 19, 2008 | 01:45 PM
Originally Posted by Daniel6718
guess my old thread go too long for anyone to help me out so here.....
Your post is still here, and easy to find. Left-click on your screen name, and it will give you an option a list of all your posts. You lose a lot of continuity, cause people to repeat suggestions that have already been offered and checked out, etc.
https://www.camaroz28.com/forums/sho...d.php?t=562255
That thread was just barely on Page 2 of the current topic listing when you made your new post.... hard to understand how you couldn't find it.
Old Jan 19, 2008 | 04:15 PM
Daniel6718's Avatar
i could find it...but i did ttt like 5 days in a row with no responses...most people i guess dont wanna read 2 pages....somehow i had 3 responses in 1 day with this new one....
speedy...i checked the iac by shbox site and it was perfectly within speck...thuoght it might have been clogged so i put on another one still same problem?
Old Jan 19, 2008 | 04:27 PM
BAMF's Avatar
what about i faulty maf not nessarley bad but lazy
Old Jan 19, 2008 | 06:32 PM
Daniel6718's Avatar
maybe rich/lean but i doubt a maf would cause ia high idle...its relaly like its got a vac leak but ive been over this again and again...even checked the injectors o rings...now im leaning to its gota be a sensor...
might need to borrow your maf and map
Old Jan 20, 2008 | 06:55 AM
Guest47904's Avatar
Guest
rule in or rule out the engine control with the IAC as I mentioned before.
The reason I mentioned that is your idle is high but your IAC counts are within range. You would expect the IAC numbers to drop down to try to maintain proper idle.
Old Jan 20, 2008 | 08:03 AM
Ken95Z28's Avatar
Might have to take off the Throttle body and clean the passage ways where the IAC is installed at. Something is causing the high idle either the throttle blades open more or the IAC is not able to close all the way.
Old Jan 20, 2008 | 08:11 AM
Guest47904's Avatar
Guest
That would NOT account for the IAC numbers being normal.
Old Jan 21, 2008 | 10:02 PM
Daniel6718's Avatar
you mean unplug it(iac) then plug it back in? i did this and idle went way up to 2500 then when i plugged it in it went back down
Old Jan 22, 2008 | 05:23 AM
Guest47904's Avatar
Guest
Not sure if you're talking to me or not but....
After you pull the pintle out further and install the IAC, leave it disconnected so the PCM doesn't try to move it. Remember you want to completely close off the IAC passage to see if air is getting in somewhere else.
Old Jan 22, 2008 | 11:08 AM
BAMF's Avatar
i think what speedy is saying is when you pull the pintal up, your disabling the iac then bolt it back up so its blocked off then leave it unplugged then watch and see what it does.?
Old Jan 22, 2008 | 11:12 AM
BAMF's Avatar
why not just spray soapy water or carb spray everywere
