high flow exhaust on a budget
What do you guys think of this setup
SLP shorties
Off road y pipe
SLP cat back
Im doing this because i want to pass smog still by throwing on the stock y pipe with the dual cats for smog tests. Or if i get enough money i may buy the random technology high flow dual cat y pipe, and then should pass smog always (hopefully??)
Will i get an SES light if i normally run the off road pipe?
Opinions please...
Thanks,
Greg
SLP shorties
Off road y pipe
SLP cat back
Opinions please...
Thanks,
Greg
I believe on your 96 OBDII set-up you will get an SES light unless you run 02 sims, also with free flowing exhaust systems on OBDII cars, there is a chance you'll throw an EGR code.
Anyone else? Correct me if I'm wrong!
I probably wouldn't buy the SLPs, but who else makes a true emissions-legal header for a '96?
If you're on a budget, you should keep your stock I-pipe (cat to muffler) as it's better than most people think. Then, you could just get a better muffler and/or a cutout. Hooker makes a good muffler that will fit the stock pipes. I have a Dynomax Ultra-Flow Welded muffler myself; sounds really good and they flow really well.
alex5366
Mar 8, 2015 11:32 AM
jeff94z28
Sep 11, 2002 02:01 PM
