hey guys
Old May 18, 2010 | 06:53 PM
  #16
JuicedZ28's Avatar
Originally Posted by byrons1502
sounds like fuel pressure to me. rent a cheap gauge from a parts store.
i was thinking that too, but if it was low on fuel pressure would it also cause you to smell gas when you do try to get on it? you can smell it but very very faintly
Old May 18, 2010 | 07:03 PM
  #17
dangalla's Avatar
Originally Posted by JuicedZ28
. so i should start with maybe gutting the cat or removing it?
you should start by scanning it for codes, checking fuel pressure, and even just pop the hood while its running it at night and mist the wires with some water to look for arcing
Old May 18, 2010 | 07:09 PM
  #18
JuicedZ28's Avatar
yea i found a friend who can scan obd1 cars and he has a fuel pressure gauge and tonight i'll try the mist trick. thx
Old May 18, 2010 | 09:02 PM
  #19
JuicedZ28's Avatar
well saw no wires arcing and noticed it was running rich at idle. so spark problem then? it was popping a bit at idle thru the exhaust
94Z28LS1toLT1
Mar 10, 2015 09:52 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
