Hesitations and Clicks/Leaking Oils
Old Dec 31, 2003 | 02:34 PM
PsychoJavexx's Avatar
My old 93 z28... when it's given a lot of gas, gunned, it clicks, hesitates, and then takes off. When it's slowly accelerated, it clicks and hesitates, and doesn't move. When I drop down to 2nd or Drive, it'll go. What's up with this? I have an automatic, by the way.
And also, there's oil all over the front of the engine, underneath the pulleys and stuff, and all around the oil pan, and most of the leaking oil drips close to the transmission pan. Any thoughts about anything?
Old Dec 31, 2003 | 03:55 PM
Any help, please???
Old Dec 31, 2003 | 05:16 PM
NJCustoms's Avatar
1st thing Clean ALL that crap off the front of your poor motor.
2nd Fix the oil leak (intake most likely)
3rd change Plugs, wires, fuel filter, air filter
Take it out and she what it does.
Old Dec 31, 2003 | 05:34 PM
EbeZ28's Avatar
I could be way off but your leak could be coming from the front cover (timing chain cover). If so maybe the oil has fouled your Opti? I know the optispark is sensitive to water so why not a bunch of oil? I think someone on this board even mentioned fouling their opti with a bad leak from the front of their intake manifold.
Also sounds like it could be coming from your oil pan gasket, and I would think fouling your Opti that way would be difficult (maybe not impossible). Clean that thing up and figure out where the leak is coming from is step one.
Then do the "easy" things like cheking your plugs an wires. How long has it been since you replaced the plugs?
If it is your front cover and you need to replace it you should consider replacing the water pump and Opti if they have many miles on them. If you find your opti has oil all over it during the gasket replacement swap it even if it only has a few miles on it, you'll be happy you did.
94Z28LS1toLT1
Jun 30, 2015 12:22 PM
FredM
Jun 5, 2015 05:45 AM
jocamino
May 14, 2015 07:37 AM
ad356
Apr 11, 2015 08:49 AM
Queens94z28
Dec 20, 2014 09:11 PM
