Hesitation under load/bad idle/loading up?
Old May 6, 2014 | 10:28 AM
smallblockhero58's Avatar
Having a time guys with my 1995 Z28. going to try and make this simple and understandable to figure out my problem
+Thing that have been replaced
-plugs and wires,-Distributor with cap and Rotor,-MAF -Waterpump, -ECT,
?Reason- Had a skip and 200kmiles.-found bad plug wire(got eaten by ac pulley)
-Problem now- Wants to jerk and hesitate under load, will go away after giving it hell.. Idles real low, drives great while cold. No Skipping or Hesitation without load. rev to 6grand no problem wont skip a beat. Runs Like crap until normal hwy cruising then smoothes out.
-there is damage to the IAC motor, has old coil,Please help, also have a OBD1 Scan Tool where I can read data and codes, jumped like on on shobox website. Any help or direction would be great. And as always I will fix it and post was the solution. Thanks
Old May 6, 2014 | 08:51 PM
parkers Z28's Avatar
Re: Hesitation under load/bad idle/loading up?
Taking a shot in the dark .... ICM ??? .....check the fuel pressure
Old May 7, 2014 | 06:37 AM
yeah I need to check the fuel psi, I just burnt 5 gallons of gas in 20 mile trip. blowing black smoke bad
Old May 7, 2014 | 09:23 PM
problem fixed- oil leaking on o2 sensor.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
