hesitation and intake backfire
Old May 15, 2008 | 10:36 PM
lt1 beast's Avatar
i have 32lb injectors and a pcmforless tune on the car. Stock tb and fuel system. I believe it to be running to rich. also i have only gone around the block 4 or 5 times. Do i need to drive for the pcm to learn the engines needs?
Old May 15, 2008 | 10:44 PM
Stl94LT1's Avatar
If it is backfiring through the intake, the PCM won't "relearn" to correct that. Sounds like your timing may be off. Are you certain the timing gears are aligned right?
Old May 17, 2008 | 09:16 AM
lt1 beast's Avatar
as sure as i can be.. i had the motor built by a professional.
Old May 17, 2008 | 10:01 AM
mrmint69's Avatar
Do you have anyway to datalog and see whats happening?
Old Sep 3, 2008 | 10:57 PM
i420tom's Avatar
did you get ur intake backfire fixed? Mine will do it at low rpms <1800 when i get on it only. Been driving me crazy for 6 years now.
jocamino
May 14, 2015 07:37 AM
Chet1185
May 10, 2015 09:24 AM
Drtryder
Apr 22, 2015 04:17 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
IRABuss
Sep 7, 2011 09:08 PM
