Hesitation, confusing symptoms help
Old Mar 10, 2003 | 05:19 AM
jj93z28's Avatar
Ok, I allways have noticed that my car does not have the punch it should at lower rpms(2000-2500). But lately the car bucks at full throttle in 4 gear at higher rpm and the other night it felt like the car hit the limiter at around 5200rpm, it very slowly pulled to redline. The thing is it is fine at high rpm in 1st, 2nd and 3rd. The car also idles perfectly at 800rpm. The car doesn't backfire, just some popping but thats just when cruising. The car is hard to turn over when its warm, but not when its cold. What do you guys think? FYI its a 93 z28 with 6 spd and 3.23 gears I changed the fuel filter a couple of months ago.
Old Mar 10, 2003 | 09:09 AM
JG94Z28Con's Avatar
Cool
Hesitation, stumbling--- I don't know if this will help... Mine was stumbling and it sounded like I had a valve tap. It shook when I gave it gas on the highway and it was running very badly at low rpms after it warmed up. I went nuts trying to find the problem. I had a similar problem with my Plymouth Voyager for a long time.... Yup, I use the same gas station for both cars... I put in Sunoco 94 and a bottle of STP fuel injection cleaner. My LT1 is running like a dream. No tapping at all, no hesitation, ready for race day...And my voyager... I still give it the cheap gas, who cares right? Remember, in the winter time a lot of areas switch to oxygenated gas mixture.
Old Mar 10, 2003 | 09:48 AM
94T56T-TOPDREAM's Avatar
same symptoms...everyone said it was my opti screwing up. Tried plugs and wires....but that didn't work.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
tdigger9899
Sep 7, 2015 10:56 AM
