Hesitation and Backfire
Old Jul 29, 2005 | 04:39 PM
JaWdRoPn's Avatar
Hey guys I have 97' T/A and my motor hesitates when I step on the gas, and stumbles. Also backfires when full throttle at high rpm's. Check plug wires all good, plugs are 6 months old, have new delteq and fuel pump. I have 96,000 miles on my car, what do you think I should look for?
Clogged fuel injectors?
bad fuel pressure regulator?
vacuum leak?
Old Jul 29, 2005 | 04:42 PM
BUBBA's Avatar
Re: Hesitation and Backfire
When did it start doing this, i.e, after doing something to the engine; before changing the plugs, opti, etc. Let's narrow it down. JMHO
Old Jul 29, 2005 | 05:02 PM
JaWdRoPn's Avatar
Changed to delteq about 8 months ago, changed all plugs and wires then. Just checked plug wires last night, all good, check them for resistance of course not just an visual check. Fuel pump is about 4 months old. Haven't worked on the car in last few months.
Old Jul 29, 2005 | 09:54 PM
Netwrkengeer's Avatar
Need more details.
Could be ICM and/or Optical sensor in Opti spark.
Or a huge list of other things.
check out this thread we are all working on a similar problem.
http://web.camaross.com/forums/showthread.php?t=371298
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
tommalcolm
Sep 11, 2015 03:39 PM
