Hesitation at 2k rpm
Car is a completely'94 Z28 with 145,000, that I bought last week. Before I bought it, it had been driven 3 times in the last year. This only occurs about 40% of the time. The problem is when the tach reaches 2k the motor sputters/hesitates, once the rpm's get above 2k the motor runs fine. This only happens at 2, rpm's. Any suggestion?
Easy to test the EGR, just remove the vac line and plug it and take it for a test drive.
If you feel it's the opti, a dealer can scan it quickly enough and confirm it.
Based on several other peoples experience on the board, you may want to save time and a lot of money by having the dealer scan it and you do the actual work.
techstar
Aug 6, 2015 11:20 AM
zajones
Jul 30, 2015 02:18 PM
