heres a ? I'm sure Shoebox will love!
Old Mar 9, 2005 | 08:38 AM
  #16
SILVERZZ28's Avatar
Re: heres a ? I'm sure Shoebox will love!
Originally Posted by shoebox
Tie the output of the thermo switch to a relay that can supply a ground to both fan relay wires.
I know that some cars have this from the factory, but I don't really see the point. Unless you have an electric water pump to also circulate the coolant, the engine is not going to get any cooler.
The ignition has to be on for this to work though.
Old Mar 9, 2005 | 09:09 AM
  #17
The added relay can be wired to an always hot source.
There is no info provided on what year your car is (pet peeve ), so I cannot tell you if the stock fan relays will work with the key off (96-97s do).
Old Mar 9, 2005 | 01:03 PM
  #18
DrewHMS97SS's Avatar
You can look at the manual fan switch wiring diagram for OBD-I (what you have on a 1994) on my Tech Page. Depending on how you hook it up, you might not even need any resistors.
I actually don't have any fan switches on my car, but do have two LEDs to tell me when the fans are on.
that is pretty cool. how do you change the a4 shifting points with the button?
Old Mar 9, 2005 | 02:17 PM
  #19
SILVERZZ28's Avatar
95. So u have another way to make the fans stay on after the key is off other than using the blue and green wires?
Old Mar 9, 2005 | 10:24 PM
  #20
SILVERZZ28's Avatar
Ttt
Old Mar 10, 2005 | 09:56 PM
  #21
SILVERZZ28's Avatar
Shoebox...Any ideas?
Old Mar 10, 2005 | 10:18 PM
  #22
It's a feature built into the PCM of 94 and 95s and was a factory option on the Firebirds but not Camaros (all you have to do on the Camaro is add a button to activate it).
The PCM has two different sets of shift tables (and other transmission parameters). One for performance mode and one for standard mode. You just press the switch to toggle between them at any time.
Old Mar 10, 2005 | 10:28 PM
  #23
In the case of a pre-96, you could use another added relay to provide the power to operate the fans with the key off . There are several different ways you could make all this work. It's just a matter of looking at the factory schematic and adding in what you need.
Old Mar 11, 2005 | 01:10 AM
  #24
SILVERZZ28's Avatar
Need MO info
Old Mar 11, 2005 | 09:23 AM
  #25
1redTA's Avatar
hey Mike your car is fast enough ... hey guys please don't help him any more
Old Mar 13, 2005 | 11:10 AM
  #26
LT1Squirrel's Avatar
would this fan switch http://shbox.com/1/fan_sw_diagram1.jpg be the same for 93 cars?
Old Mar 13, 2005 | 12:05 PM
  #27
It will work on the 1993-1994 2 relay fan system. Just remember that those fans work as primary and secondary and not low and high speed like the later 3 relay fans do.
Old Mar 14, 2005 | 09:04 AM
  #28
SILVERZZ28's Avatar
I looked . No way to make this work easily
cmsmith
Sep 14, 2015 09:25 PM
97blackformula
Aug 27, 2015 06:02 PM
WPHIG2
Aug 27, 2015 06:37 AM
Aug 7, 2015 01:26 PM
