HELP Where does the factory tach get its power/reading from?
Old Jul 27, 2003 | 07:09 PM
TexasTechTA's Avatar
If I can pinpoint where this is I can figure out ym electrical problem. thanks
Old Jul 27, 2003 | 07:52 PM
The tach is connected to the PCM on pin 13 of the red connector (C1). Where does it get the info to provide the signal? The opti, of course.
Old Jul 27, 2003 | 08:17 PM
the signal for the tach in the opti is it high or low resolution? I thnought the tach ran off the coil.
Old Jul 27, 2003 | 08:44 PM
I believe the pcm uses both high and low for spark determination.. The tach is driven off the pcm as stated earlier.
Old Jul 27, 2003 | 09:06 PM
Fastbird93's Avatar
The tach gets it's signal from the coil, and through a filter that's taped to the wiring harness right next to the coil, then straight to the tach.
Old Jul 27, 2003 | 09:12 PM
thanks I just want to know which one it is shoebox says the tach runs off the opti and pcm and you say it is the coil It hought it was the coil but shoebox said no does anybody know 100 percent?
Old Jul 27, 2003 | 09:19 PM
I think i? figured out wehy the car is hard to start and the tach went out when i did the comp test on my car I did not pull the ign fuse so the spark from the coil shorted the wire on the coil that goes to the tach which connects to the otpi. so the high res is ogne on the opti. does that seem possibler I do not have an olmeter to check but I am taking it in tomm shoebox what do you think?
Old Jul 27, 2003 | 09:23 PM
Looky here and find A13 (tach output). It goes from the pcm to the tach.
The coil also gets it's firing signals from the pcm (see B5 [ignition control] at the bottom of this diagram.
There are no wires from the coil to the tach that I can see.
Then again, a 1993 might be different.
Old Jul 27, 2003 | 09:26 PM
Fastbird93's Avatar
93's may be then. I just had the service manual out and was looking at the wiring schematic because I'm trying to figure out my tach signal problem. Sorry to cause any confusion.
Novo
Jun 14, 2016 02:58 AM
magman
Apr 15, 2016 03:08 AM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
Stephen68
Oct 16, 2015 03:50 PM
football4life
Oct 4, 2015 07:48 AM
