HELP! What Type Of Sealant To Use On Gas Line/Finttings??
Old Apr 4, 2003 | 12:26 PM
COMNBYU's Avatar
ok, where my fuel filter goes into the fuel solinoid leaks very slowly. over time it drenches the driverside valvecover and starts to smell like gas in the car. it's become a big annoyance.
now, i originally tried just teflon tape on the threads. that worked for a little while, then stared leaking again. next, i tried tepflon paste. same results. finally, i tried a combination of the two which lasted a little longer but still ended up leaking. i thought the threads could possibly be crossthreaded, but after thorough inspection, they check out fine.
i ran a entire fuel system on my old chevelle and used the tape with that and NEVER had a problem. so im baffled as to what i should use? anyone got any suggestions??
how about any of the RTV sealants?? the red/blue/black?
thanks in advance, jon
Old Apr 4, 2003 | 12:30 PM
Don't know how much telfon tape you wrapped on it, but maybe you need more. Perhaps that fitting is just a "loose" one. If there is a flare to it, make sure there are no burrs or damage to it.
Old Apr 4, 2003 | 01:57 PM
When you start talking about fuel filter and fuel solenoid, I assume you are talking about a fuel supply for a wet nitrous system??? What are the details of the connection.... -AN? ..... NPT? Obviously the -AN should not use any sealant. The typical Teflon tape should easilly hold the fuel pressure with healthy NPT threads. One of the parts if faulty and should be replaced. I personally wouldn't risk a fire. Putting more sealant on it isn't the way to go.
Old Apr 4, 2003 | 04:38 PM
David96Z's Avatar
I wouldn't use teflon tape on it i would use liquid thread sealant
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
zajones
Jul 30, 2015 02:18 PM
surreybrad
Jul 29, 2015 02:55 PM
CARiD
Jul 7, 2015 08:19 AM
SergheiS
Jul 5, 2015 03:27 AM
