Help .... what do I do now?
Old Jul 27, 2003 | 03:28 PM
NAZTLT1's Avatar
Removing exhaust manifold on driver side. All the bolts came off fairly easy except for one. It's the bolt on the front side of the last port and the bolt is fused to the spacer(rust). I let it soak in pb blaster and tried it again and rounded the bolt. How am I going to get this bolt out?? Anyone else had this misfortune and if so how did you solve the problem. Your suggestiond are greatly appreciated.
Old Jul 27, 2003 | 03:29 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Help .... what do I do now?
Weld a wrench to it/
you should have heated it up. it woulda came loose a lot quicker
Old Jul 27, 2003 | 03:35 PM
AsianSensation's Avatar
Don't they sell rounded bolt removers?
Old Jul 27, 2003 | 04:09 PM
94formulabz's Avatar
yes they do.
You could grind flats on each side and try to use an adjustable wrench or smaller size.
Slot it in the middle and make a flathead screw out of it.
Or the best option might be to cut the head off the offensive bolt, then remove the manifold. If the remaining stud won't turn out by hand, you'll definilty be able to get it with a visegrip.
good luck.
-brent
Naanz
V6 Tech
Feb 14, 2016 11:11 AM
WPHIG2
Aug 27, 2015 06:37 AM
Ted 99 TA WS6 Conv
17
Feb 21, 2003 09:43 PM
PacerX
27
Feb 18, 2003 08:53 AM
pillagenburn
Jan 24, 2003 01:05 PM
