help with waterpump and pulley!!!!
i have a problem ,i cant take the pulley bolts out. im doing an opti install and when i try to turn the bolt the whole pulley moves so i put the car o 1st gear and when i turned i heard a noise from the tranny i guess . so how can i turn the bolts w/o the pulley moving? and also do you put rtv sealant on water pump gaskets??
thanks.
thanks.
Re: help with waterpump and pulley!!!!
thanks.
thanks.
Put a 1/2" breaker bar and the correct socket size for the crank-hub as a backup, while using the same for the pulley, pull and push technique.
Yes use some good Permatex Hi-Temp RTV (orange, etc) for the water pump gaskets, make sure you clean them good. You don't have to take the hub completely off just has to be turned a certain angle to allow opti removal clearance. Shoebox's site I think has the pics for the position if you don't already have it.
good luck,
Brett
ok i got the bolts out thanks but the pulley wont come oput
what can i do? ive been hammering it for 3 mins.
thanks
thanks
RUENUF
Mar 13, 2016 03:37 PM
