help with waterpump and pulley!!!!
Old Apr 13, 2004 | 06:41 PM
cridom's Avatar
i have a problem ,i cant take the pulley bolts out. im doing an opti install and when i try to turn the bolt the whole pulley moves so i put the car o 1st gear and when i turned i heard a noise from the tranny i guess . so how can i turn the bolts w/o the pulley moving? and also do you put rtv sealant on water pump gaskets??
thanks.
Old Apr 13, 2004 | 06:48 PM
Brettinator's Avatar
Re: help with waterpump and pulley!!!!
thanks.
Lot of WD-40, etc
Put a 1/2" breaker bar and the correct socket size for the crank-hub as a backup, while using the same for the pulley, pull and push technique.
Yes use some good Permatex Hi-Temp RTV (orange, etc) for the water pump gaskets, make sure you clean them good. You don't have to take the hub completely off just has to be turned a certain angle to allow opti removal clearance. Shoebox's site I think has the pics for the position if you don't already have it.
good luck,
Brett
Old Apr 13, 2004 | 07:58 PM
Mike383LT1's Avatar
pulley spining
you can also try an impact gun
Old Apr 13, 2004 | 08:00 PM
CeeBee94Z's Avatar
Put it in a higher gear like 4th or higher...that should keep it from turning at all.
Hope that helps
Old Apr 13, 2004 | 08:03 PM
cridom's Avatar
ok i got the bolts out thanks but the pulley wont come oput
what can i do? ive been hammering it for 3 mins.
thanks
Old Apr 13, 2004 | 08:37 PM
CeeBee94Z's Avatar
thanks
3 claw puller and it will come off extremely easy. Just go rent one at autozone and then return it. Costs ya nothing in the end. You shouldn't use a hammer to begin with.
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
reww86
Aug 29, 2015 06:04 PM
MikeWhitener
Aug 2, 2015 06:17 PM
