Help with water pump on 94 trans am
Old Jan 3, 2005 | 05:08 PM
N2O_Formula350's Avatar
Exclamation Help with water pump on 94 trans am
Need help with 94 trans am water pump replacement!
I read on some site that there 6 bolts holding the water pump on (haven't bought the new one yet for reference). I found the three on pass. side and two on the driver side. Where is the other bolt? Do I have to take of the air pump?
Thanks for the help.
Old Jan 3, 2005 | 05:09 PM
Hawk's Avatar
Re: Help with water pump on 94 trans am
yes you have to take off the air pump and the bracket under the air pump. YOu will then see the last bolt.
Brian
Old Jan 3, 2005 | 05:11 PM
Dammit, I knew it.
Thanks for the quick help Brian!
Old Jan 3, 2005 | 05:19 PM
30696bird's Avatar
Mine don't have a air pump..........I took it off and ummmmmm "forgot to put it back on! lol
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
pologreen97z
Dec 2, 2014 10:42 AM
