help!! want to get into 12's!!!!
Old Aug 11, 2006 | 02:10 PM
cody_19wv's Avatar
My 95 (see in sig) i was wondering what i could do to get into 12's where my dad's zo6 is? I just redid the rear end 10 bolt with 373's and i want something that wont destory it. A small H/C setup? If so please be specific on costs and labor and reliability of this job. Also what would i be pushing horsepower wise? What else would i have to change? PLEASE HELP.
thanks
cody
Old Aug 11, 2006 | 02:20 PM
Javier97Z28's Avatar
Moderator
Re: help!! want to get into 12's!!!!
Your sig needs a better breakdown....
You have stock compression pistons? a new stock cam? new stock rockers? What exactly do you have done.
All an A4 needs to get in the 12's is intake/headers/exhaust/stall converter and sticky tires.
Old Aug 11, 2006 | 02:22 PM
CustomSSI's Avatar
Well first off where are you located? And are you wanting high 12's? That should be fairly easy with all bolt ons and a good stall (your auto correct)..... If your wanting deep 12's your going to have to go with a cam or a H/C setup... A mid range cam will get you there with stock heads. Pretty much anything that hooks really hard will eventually break the 10bolt unfortunately... :-/ If you got any questions feel free to contact us..
Josh
Old Aug 11, 2006 | 02:28 PM
Moderator
Josh
Most A4 car rears will survive a while with a T/A girdle. Mine has 300+ passes and still chuggin. I can cut 1.6's with ease.
Old Aug 14, 2006 | 11:13 AM
cody_19wv's Avatar
everything that was rebuilt in the motor was built back to stock. the bottom end wasn't touched. it was bored .30 over, my dad's corvette runs a 12.2 - 12.6 i want to be able to run with him better than i do now. i've never been to the track so i do n't know what i can do now.. .. what kinda intake to you mean. i have a k &n cold air intake. and what kind of headers should i get? shorties? whats the difference in price and performance, keep in mind im gonna be doin the work myself . and what kind of exhaust i have a hookercatback exhaust. please be VERY specific . im not as pro as you all are aobut this stuff, thanks
cody
Old Aug 14, 2006 | 01:37 PM
mattybz28's Avatar
Just so you know, lt1's have a single cam, not "cams" like your sig says.
Old Aug 14, 2006 | 02:23 PM
mkent's Avatar
I think a CC306 cam (and 1.6 roller rockers and higher lift valve springs) with Hooker long tubes or even Pacesetters (for the money, they're a good header), and the already mentioned, stall converter (2800 or even up to a 3200 stall speed) and drag radials. Of course a nice port and polish on the heads would really seal the deal nicely, but if money won't allow it, just give the cam kit, stall, and tires a try.
Old Aug 14, 2006 | 04:11 PM
cody_19wv's Avatar
how much would the cam cost? with labor? and what about the stall? labor and parts what would i be looking at WORST case scenario. thanks alot you all are alot of help.
cody
Old Aug 14, 2006 | 06:50 PM
BassProCamaro97's Avatar
What about for a M6?
~Jim~
Old Aug 14, 2006 | 07:08 PM
1racerdude's Avatar
There are better cams than the CC306.
Contact Loyd Elliot on the board vendor and talk to him about a set of heads and cam,a matching set, and porting the intake.
Get headers and exhaust and a converter and some sticky tire and ya should be there,maybe way past into the 11's.
Or a 150-200 shot of hose.
Old Aug 14, 2006 | 07:39 PM
cody_19wv's Avatar
Ok a cam..... but how much are we talkin here? And what kinda exhaust ? i have a hookercatback on now is that not good enough? and the converter how much would this cost? I just bough a new set of sticky tires and they hook up well
Old Aug 14, 2006 | 07:55 PM
1racerdude's Avatar
Converter about $700
Headers and "Y" pipe about $800
Cam,RR's,springs, retainer,locks about $1000
Your castings ported and ready to bolt on about $2000+
Port intake about $500
Injectors about $500
Gaskets about $200
Tune about $200
Personal satisfaction, priceless.
Old Aug 14, 2006 | 08:01 PM
IdahoLT1's Avatar
An out of the box cam should run about 250-400$. Im not sure about a custom grind cam. If youre running street tires and theyre hooking now with boltons they wont be with a cam or h/c combo. you need atleast drag radials or street slicks. About exhaust ive heard alot of people like gmmg or 2.5" true duals.
The price will vary by quite a bit. Parts alone could run 1000-2000$ depending on what setup you go with. And $3000+ if you want to prevent breaking things you might have to upgrade the transmission (depending on how much hp/torque you make) and upgrade the rearend and other parts of the driveline/suspension to handle the sticky tires.
Old Aug 14, 2006 | 08:10 PM
cody_19wv's Avatar
i really don't have 4 grand to spend on the car though. see the original post .....im lookin for the cheapest way to get into mid to high 12's...i don't wanna outrun my dads zo6 i just want to run with him. what would be my best bet with around a grand?? I don't want to use spray i think thats cheap and i don't think my bottom end could handle it anyways. Could i get away with JUST a cam? what would that do? plus...what could i do by my self to save labor? any thoughts ?????
Old Aug 14, 2006 | 08:16 PM
kainZ's Avatar
Add some 1.6 rr (like comp pro mag 7/16 nsa-- you need guideplates and 7/16" studs)
oh you already have rockers.. ok put the last couple hunge tward an electronic cutout instead.
