help on unnon rockers
Old May 3, 2007 | 10:39 AM
pat35's Avatar
has any one used these rockers.i nead a set .just cant find any info on them.
the gy sead they ar as good as the comp and lock much better i will be bying them to day inles ane one her sees a problum sare about the spelling i have deslixia and no spell check her at work.
Old May 3, 2007 | 01:52 PM
pat35's Avatar
has any one seen these
Old May 3, 2007 | 02:24 PM
BUBBA's Avatar
Look pretty good to me---you will probably need to install some 7/16 studs, since I believe the stockers are 3/8. Also, they appear to be non-self aligning so you will need to get guide plates, hardended push rods, and of course you will need much better than stock springs, regardless of which brand of rrs you get. BTW, I assume these are 1.6 Ratio. JMHO
Old May 3, 2007 | 02:39 PM
pat35's Avatar
yes 16 .have new 7/16 studs and new comp cromoly pushrods and trick flow rid plates.just wandering about the quality . i never seen these befor . tring to see if any one has used them. or knows ane one that has used them. dont see the oiling hol must be on the side so they arent exacly like the comps
Old May 3, 2007 | 03:01 PM
BUBBA's Avatar
Well, apparently the seller has used them---if he wasn't a long-time member in good standing (so far) then I would be a bit concerned, however as far as I know he is upstanding and wouldn't do you wrong. JMHO
Old May 3, 2007 | 10:12 PM
pat35's Avatar
ok thank you everyone, you have been a great help. I bought the rockers, the machine shop said they were made by comp and they were the same as the 400.00 stainless rockers.he wants 265 shiped
Pat
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
