Help, Timimg problem, ChangedOPti, Won't run
Old Sep 11, 2005 | 09:16 PM
stepuptata's Avatar
I have a 97 Z28. Changed the opti, and now the car starts up but instantly quites. It keeps doing this. I changed the opti on my 94 TA and it started up and ran good, no timing issues. Are the 97's Z28 differenent since they have that "pin" on the crank and not the "spline shaft" like the 93-94. Thanks for the help, Troy.
Old Sep 11, 2005 | 09:45 PM
Canuck wita WS6's Avatar
Re: Help, Timimg problem, ChangedOPti, Won't run
$20 says you don't have the opti on correctly. Check to make sure the dowel pin is in the correct hole on the backside of the opti.
http://shbox.com/ci/opti_mounting.jpg
Old Sep 11, 2005 | 11:08 PM
http://shbox.com/1/opti_back.jpg
It may also do that if you don't have your MAF plugged in.
DirtyDaveW
Dec 1, 2016 05:37 PM
Jessie4tin
Jan 7, 2015 08:53 AM
nophix
Nov 30, 2014 10:26 PM
guionM
14
Jun 19, 2002 08:30 AM
