Help, There is a knocking/Chopping noise
There is a knocking or chopping noise comming form the left side of my engine compartment it is very slight at idle but it gets louder while acelerating anyone know what this is?
Re: Help, There is a knocking/Chopping noise
Exhaust leak..... One of your manifold bolts probably sheared off due to Different expansion rates between your aluminum heads and cast iron manifolds.... Very common....
If the bolt is broken off below the surface of the head it'll be a serious pain in the butt. Check the bolts before you start taking stuff apart..... I'll bet it's one, or both of the bolts on #7....
autoxr166
Sep 25, 2015 04:21 PM
colts0455
13
Aug 7, 2015 09:15 PM
