Help temp up
Old Apr 19, 2007 | 03:52 PM
slicknick54's Avatar
Help temp up
I installed pacesetter lts on my 97 camaro, in doing so i bent the two prongs on the coolent sensor for the temp gauge. i unbent them and put everything back together. started my car up and the temp climbed to 230 in 5 min. Belt is on properly. coolent was replaced when the little fell out from finally taken the sensor out due to bending it. fans kick on. do you think the sensor is bad or what? Im confused and just want it fixed. thanks.
Old Apr 19, 2007 | 04:55 PM
joeSS97's Avatar
did you bleed the system? If not that could be the cause.
Old Apr 19, 2007 | 05:42 PM
transAMdriv3r's Avatar
i don't know, i don't think the temp can climb that quick. I think you may have broken the sensor. My car take 5 min just to start warming up.
Old Apr 19, 2007 | 06:04 PM
2000GTP's Avatar
You can verify that the sensor is working properly if you have access to a multimeter: http://shbox.com/1/4th_gen_tech2.html#ect
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
