help with some valve covers
Old May 18, 2006 | 08:18 PM
chrisbz28ss's Avatar
Unhappy help with some valve covers
i got some trick flow heads from summit with gold racing roller rockers. now i have a big problem my valve covers will not fit. i called summit to get some bigger ones and the guy said they didn't make any. if i got any biger ones they would hit my brake boster.he said try using two gaskets. i don't want to have to do that (besides i don't think that will work i have spent to much money on it now for this bull) anyone know what i can do? thanks it's for an lt 1 95
Old May 18, 2006 | 09:34 PM
MyShibbyZ28's Avatar
Re: help with some valve covers
Center bolt to perimeter bolt cover conversion. Just a suggestion.
Old May 18, 2006 | 09:38 PM
OBE1 95Z28's Avatar
Your rolling rockers may be spaced close together and the ribs inside the valve cover that support the center bolt tubes may be the source of your interference. The ribs can be flatten to clear the tight spacing.
Old May 18, 2006 | 10:31 PM
CANTONRACER's Avatar
Brake booster? You don't have a 69 Camaro there bud...gotta love Summit Racing.
Old May 18, 2006 | 10:40 PM
Kevin Blown 95 TA's Avatar
Trim the stock supports or get plastics.
Old May 19, 2006 | 09:34 AM
rondav WS6's Avatar
Jegs has some that fit larger rockers
Old May 19, 2006 | 09:41 AM
You've got at least 5" clearance between the stock valve cover and the brake booster..... taller covers will NOT be a problem. You just need to make sure they have been clearanced for the alternator on the passenger side.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
