Help on SLP header install
Old Feb 7, 2005 | 01:05 AM
150&6K's Avatar
I am installing a set of SLP headers for my 96 Z28 and yes, they are the ones for the duel cats. The problem is that I can’t seem to get the passenger side header in. I have tried going from the bottom and the top and can’t get that stupid triangle flange to clear either way. I have removed the back two spark plugs and the oil filter and this still doesn’t work. If you have or know about this problem, please help before I start unbolting engine mounts
Old Feb 7, 2005 | 01:45 AM
Built on Sin's Avatar
Re: Help on SLP header install
Try removing starter and valve cover for more room. Good luck with the 2nd and 3rd bolts from the rear. Those headers are a pita!!
Old Feb 7, 2005 | 02:00 AM
Z95m6's Avatar
if nothing else pull the motor mount bolt and jack up the motor on that side.
Jlo
Feb 23, 2015 12:20 PM
jim88iroc305
Aug 13, 2002 09:24 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
