help..short header's, and auto trans????????
Old Feb 2, 2003 | 11:05 AM
ex-ohp's Avatar
Talking help..short header's, and auto trans????????
what should i do.I can't run long tubes on my car is it worth it as far as $$$$$ to do the short headers..$$$ vers HP gains. and should i flush the trans or drop the pan on a service...what will clean it better..thanks for your help...97 A4
Old Feb 2, 2003 | 11:30 AM
Greasepunk's Avatar
Why can't you run long tubes? Emissions? and shorties vs stock, yeah I would go with shorties...
Old Feb 2, 2003 | 12:33 PM
drop top steve's Avatar
Re: help..short header's, and auto trans????????
Shorties well give you a seat of the pants increase and keep all emmisions intact. Pull the pan and change the filter, refill, then pull the cooler line, rubber hose near radiator, place in a large drain pan, start the car and run for a few seconds, then top off the trans and repeat till fresh fluid comes out the cooler line.
Old Feb 2, 2003 | 01:40 PM
chesee48's Avatar
you have no other choice, so Get them!
SinisterRacing1
Mar 7, 2015 03:44 PM
Moshbmx1
Feb 17, 2015 10:51 AM
jb4xx
Feb 2, 2015 10:00 PM
rockync7
Jan 1, 2015 05:10 AM
Sarahrope64
Nov 27, 2014 11:17 AM
