HELP - Replacing Radiator
Old Feb 26, 2003 | 10:52 PM
ut's Avatar
ut
93 Camaro M6 - no oil cooler. I'm swapping out the cracked radiator with a new one. I've got it drained, fans off, and all hoses off. How do I get the AC condenser out of the way? Do I need to worry about disconnecting the line running to it on the bottom passenger side? Also, should I pull the radiator out from the top or the bottom? Any help would be appreciated, 1st time doing this.
Thanks.
Old Feb 26, 2003 | 10:57 PM
Kris93/95Z28's Avatar
the condenser should be able to be pryed up, and the radiator pulls out from the top.
The lines to the condenser don't need to be pulled Hope this helps!
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Jazsun
Dec 29, 2014 12:14 PM
