HELP - Replacing Radiator
93 Camaro M6 - no oil cooler. I'm swapping out the cracked radiator with a new one. I've got it drained, fans off, and all hoses off. How do I get the AC condenser out of the way? Do I need to worry about disconnecting the line running to it on the bottom passenger side? Also, should I pull the radiator out from the top or the bottom? Any help would be appreciated, 1st time doing this.
Thanks.
Thanks.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Hope this helps!
