Help removing water pump
Old Jul 13, 2005 | 05:26 PM
Detroit808's Avatar
I'm replacing my broken water pump with another stock pump, but I can't get it off. I removed 5 bolts holding the pump on, and one nut on the driver side. Now there's a threaded shaft where the nut came off, going through a bracket that looks unrelated, then the water pump, then into the block. (Let me know if that makes sense, I'm trying my best.) Did I snap the bolt head off, or is this really a nut? In either case, where do I go from here?
Old Jul 13, 2005 | 05:37 PM
96lt1Camaro's Avatar
Re: Help removing water pump
did you take the air pump and its bracket off first?
Old Jul 13, 2005 | 05:46 PM
Detroit808's Avatar
Doh...I'll try doing that now, thanks!
Old Jul 13, 2005 | 06:13 PM
MPZ28's Avatar
are'nt there 6 bolts that hold the water pump on ? And the threaded bolt he is talking about hold the air pump.
Old Jul 13, 2005 | 06:16 PM
Yes, there are 6 bolts.
HectorM52
Jul 30, 2017 11:46 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
