HELP! Removing passenger side header
Old Feb 23, 2003 | 05:45 PM
DjArcadian's Avatar
Question HELP! Removing passenger side header
Okay, I have all the bolts removed and it's sitting free. Do I have to remove the oil dip stick and spark plug wires (they're NOT over-the-valve-covers) to get them out? I've tried wiggling them it's luck. Do they have to drop out the bottom or can I pull them through the top?
Old Feb 23, 2003 | 05:50 PM
joeSS97's Avatar
What kind of headers?Most likely you have to take the plugs out.
Old Feb 23, 2003 | 05:52 PM
DjArcadian's Avatar
JBA Shorties
Old Feb 23, 2003 | 05:59 PM
94Sleeper's Avatar
I'm not sure about the JBA headersas I have AS&Ms. In either case I can't see how you can remove them through the top. I have always had to remove the plugs, dipstick and starter to drop these out the bottom.
Good luck
Old Feb 23, 2003 | 06:49 PM
96cam4ro's Avatar
Wink
Somehow I managed to pull my pass. side header from the top. You need that dipstick out of the way. It takes some shoving.
alex5366
Feb 17, 2015 10:43 PM
Jul 4, 2005 05:00 PM
blue89iroc
Jul 26, 2002 04:56 PM
