HELP! Removing passenger side header
Okay, I have all the bolts removed and it's sitting free. Do I have to remove the oil dip stick and spark plug wires (they're NOT over-the-valve-covers) to get them out? I've tried wiggling them it's luck. Do they have to drop out the bottom or can I pull them through the top?
I'm not sure about the JBA headersas I have AS&Ms. In either case I can't see how you can remove them through the top. I have always had to remove the plugs, dipstick and starter to drop these out the bottom.
Good luck
Good luck
Jul 4, 2005 05:00 PM
