help rebuilding
Old Jun 2, 2007 | 03:44 PM
93camarochrisz28's Avatar
help rebuilding
i needed a little help i want to rebuild my 350 and i am looking a cranks a pistons what would be a good all around set up any help is good help
Old Jun 2, 2007 | 05:53 PM
FlamingChicken's Avatar
i think the best thing to do would be to sit down and think what you want your goals to be. piston choice is probably gonna be the hardest since you will need to build for na, spray, or boost. i am buying all my stuff separate instead of a kit but am using a lunati sledgehammer stroker crank, lunati pro mod 6" rods, and still unsure on the piston. have fun with the build
Old Jun 2, 2007 | 09:04 PM
windsma's Avatar
same deal here but when i got the motor apart my cly. are rusted from a blown headgasket i now have to find a good lt1 block. this set me back atleast 1 mo., give us a budget and we can help out further.
Old Jun 2, 2007 | 11:24 PM
i have around 1300 to spend on this build for right now came at a bad time to spin a rod bearing lol
Old Jun 3, 2007 | 03:32 AM
95fbformula's Avatar
Unless you are building a stroker you probably wont need a new crank just get the stock 1 polished and turned if needed. As for pistons i used mahle -5cc flattops they are a pretty good piston design and light weight.
Old Jun 3, 2007 | 11:48 AM
2000GTP's Avatar
1300 for parts and labor is going to be tight. With your budget, it may be more feasible to find a good conditioned LT1 shortblock.
Old Jun 3, 2007 | 06:41 PM
i am doing alot of the work my self i have done a little bit of stuff like this just never on my own car i was looking at like summit rebuild kits and going to a machin shop to clean up the block
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ks0209
Oct 1, 2015 07:32 AM
Bxlt1
Sep 29, 2015 03:18 PM
Z Power
Sep 19, 2015 11:19 PM
