help rebuilding
i think the best thing to do would be to sit down and think what you want your goals to be. piston choice is probably gonna be the hardest since you will need to build for na, spray, or boost. i am buying all my stuff separate instead of a kit but am using a lunati sledgehammer stroker crank, lunati pro mod 6" rods, and still unsure on the piston. have fun with the build
Unless you are building a stroker you probably wont need a new crank just get the stock 1 polished and turned if needed. As for pistons i used mahle -5cc flattops they are a pretty good piston design and light weight.
i am doing alot of the work my self i have done a little bit of stuff like this just never on my own car i was looking at like summit rebuild kits and going to a machin shop to clean up the block
