HELP, quick rocker arm installation
Old Mar 9, 2007 | 03:13 PM
  #16
Z95m6's Avatar
If i was you I'd just try to very very slowly turn the motor over by hand and see if you can get lucky and have the piston shove the valve back up into the head. Using compressed air now isn't going to help as the valve is wide open. Just to note my piston stop didn't work either on my car when i was trying to degree my cam. I just threaded on a nut to it then put a tack weld on the end. I then ground the nut down so it was just small enough to fit into the spark plug hole. Then it worked great and i got my cam degree'ed in.
Old Mar 9, 2007 | 03:17 PM
  #17
danhr's Avatar
that's what I did as well.... I didn't want to crank it without anyone watching the valve, because for all i knew the piston would have been going down.... so I didn't want to turn it the wrong way.
here's a pic on how close i got..
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
1775.Z28
Jan 11, 2015 10:51 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
