Help! quick question!!!!
Old Mar 15, 2003 | 09:45 AM
95TA8280's Avatar
I'm doing tghe LT4 KM and I'm disconnecting my battery. What size socket is the negative terminal?
Old Mar 15, 2003 | 10:12 AM
BigEvil's Avatar
If you HAVE to avoid trying a few different size sockets... ...it took a 9mm for mine.
Old Mar 15, 2003 | 10:14 AM
David96Z's Avatar
It is 8mm
Old Mar 15, 2003 | 10:42 AM
95TA8280's Avatar
My socketi s too long.....can I just do it with my hand real quickly?
Old Mar 15, 2003 | 11:02 AM
BigEvil's Avatar
Mine was too.
I had to use an open end wrench.
The 8mm was too tight so I had to go with 9mm.
You can try by hand, hope you ate your wheaties
Old Mar 15, 2003 | 11:15 AM
95TA8280's Avatar
I ended up using the 8MM.......the terminal was too loose, so the ratchet wasn't really doing anything because it wasn't lined up. So I used my hand just to hold the socket as I spun it. I did it, finally.
Old Mar 15, 2003 | 11:28 AM
$hawn's Avatar
When I used a 8MM a few times it stripped mine, so I got some new bolts and now use a 5/16, it's a snugger fit.
Old Sep 27, 2003 | 03:37 PM
CamaroGuy22's Avatar
I just tried disconnecting my negative battery terminal and the nut is stripped. I cant get it off...what should i do now?
Old Sep 27, 2003 | 03:42 PM
RamAir95TA's Avatar
5/16" will work.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jan 23, 2015 01:13 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
