help quick 1.6 rr prob
i just put in a hotcam kit and im using p/n cc-1318-16 comp cams pro mag 1.6 sa rr's. prob is i keep throwing one off. doesnt matter how i tight i set them or how perfect i set it it keeps coming off of center and the tip is hitting the top of the spring retainer. wtf is goin on i need help fast. do i need guideplates. i looked at the pushorod already and its not bent. please help fast TIA
joe
joe
thanks, any more ideas...
and also i was looking at the pro mags and they dont have the ridges on the tip to hold them in place like the GMPP 1.6s do, are all SA RR's suppose to have those ridges. i ordered these direct from comp cams and they even said SA on the box. so i dont know whats up, ive never done this before so im kinda clue less thanks again
joe
joe
A friend on mine had problems like this, the RR turned and the values ate up the RR. the metal shavings got down in the pan a locked up the oil pump. As a result one new oil pan, oil pump, new rods, alot of bearings, and machine work.
Try switching it with another one.
If there isn't anything on the end of the rockers where the rollers are to keep them on the valve stem, are you sure you have SA rockers? If they don't have the "guides" on there, there is nothing to keep them aligned. Therefore why you're having problems. But 1318-16 is a self-aligning rocker, sure you have the right p/n?
I helped joe with his install, and I know for a fact that the tip of the rockers do not have a recessed area for the valve. The are just the roller tip. they look like they need guideplates, the way the one slides off the valve.
thanks for the advice everybody, i pulled all the other RR's and looked at them and you guys were right SA's have the little ridges and NSA dont.
i have 1 NSA and 15 SA RR's, gee i wonder why it kept falling off. stupid comp cams sent me one wrong roller rocker out of a full box. im calling them this afternoon to get it straightened out. hopefully they are willing to cooperate.
thanks everybody
thanks everybody
68camaroboltz
Oct 5, 2015 11:56 PM
NewsBot
Sep 14, 2015 09:20 AM
hope someone else can help with the actual problem...
