HELP! Puddle of gas on the ground...
I would first suggest taking a look around the fuel filter. There could be a bad connection around there causing your fuel leak. After that I would follow the fuel line from the fuel pump to the front of the car and see if you can see any holes, leaks, wet spots, etc. If none of that works, I would try to follow the smell if at all possible to narrow down the area of the car its comming from.
Put it up on some ramps and have a look
Good luck
Good luck
lol, sorry, I didn't have the car with me when I posted about this, and it was way to dark for me to really check things out that night.
Anyway, changed the fuel filter, the bracket that kinda supports the fuel filter was bent. I bent it back and hooked everything back up, it works great now, no leaks!
WobblySausage
Oct 7, 2015 10:09 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
