HELP! Puddle of gas on the ground...
Old Mar 31, 2004 | 01:51 PM
Tair's Avatar
I have a puddle of fuel under my car. It's leaking at the rate of 1 gallon of fuel a day. What should I check first?
Old Mar 31, 2004 | 02:09 PM
SubsAnDubs's Avatar
Which section of the car is it leaking from?
Old Mar 31, 2004 | 02:14 PM
Tair's Avatar
it SEEMS like it's leaking from the very middle of the car. I haven't had time to take a good look at it yet.
Old Mar 31, 2004 | 02:17 PM
SubsAnDubs's Avatar
I would first suggest taking a look around the fuel filter. There could be a bad connection around there causing your fuel leak. After that I would follow the fuel line from the fuel pump to the front of the car and see if you can see any holes, leaks, wet spots, etc. If none of that works, I would try to follow the smell if at all possible to narrow down the area of the car its comming from.
Put it up on some ramps and have a look
Good luck
Old Mar 31, 2004 | 02:22 PM
valter's Avatar
Lift it and look at fuel filter & fuel lines. Fix it ASAP, it's dangerous...
Old Mar 31, 2004 | 08:04 PM
Tair's Avatar
yea, gonna check the fuel filter first I guess
Old Mar 31, 2004 | 08:35 PM
ibanez6rg's Avatar
Dude, wtf? Get under your car!
Old Apr 2, 2004 | 04:15 AM
Tair's Avatar
lol, sorry, I didn't have the car with me when I posted about this, and it was way to dark for me to really check things out that night. Anyway, changed the fuel filter, the bracket that kinda supports the fuel filter was bent. I bent it back and hooked everything back up, it works great now, no leaks!
Old Apr 2, 2004 | 04:35 AM
Carpe Diem's Avatar
i was gonna say that you should teach it to take a leak on ricers, not your driveway...
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
