help with proform valve covers
Old Feb 1, 2004 | 11:16 AM
30thannZ28's Avatar
I just bought some black crinkle valve covers from proform, and I know I can use the breathers with it, but I need to know how to do the oil cap part. The cover with the oil cap hole doesn't have a grommet. Do I need one? Also, how would the PCV system work now? I bought a brand new PCV valve, but if I have breathers, do I NEED the PCV valve? Help please.
Old Feb 1, 2004 | 11:32 AM
MadMaxz28's Avatar
you can get a little rubber pushin oil cap
Old Feb 1, 2004 | 11:38 AM
Bud M's Avatar
Use either breathers or PCV, not both. The oil cap is a push in fit, isn't it? If it is it will need a grommet.
Old Feb 1, 2004 | 12:08 PM
12SCNDZ's Avatar
I've got the chromed aluminum version of those valvecovers. I'm using (2) Billet Specialties breathers with "Heartbeat" milled in them. I just pull one of them out to add oil. Your PCV valve is in your intake, not your valvecover.
Check out my website to see pictures. There are 2 engine pictures in the upper left of the opening page (they take a while to load). They will enlarge if you click on them.
One of your covers should have (2) holes...The other has (1). The (2) hole cover should go on the passenger side with the vacuum hose from the t-body going to the back one and a oil fill/breather in the front one. The drivers side just takes a breather.
Frank
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
