Help with Proform shift light?
Old Jun 29, 2003 | 04:57 PM
1Z2Z's Avatar
I installed the shift light today. As soon as I start the engine the light comes on and stays on regardless of where the RPM adjustment is.
I have the power coming from the power window fuse, and the tach lead is attached to the MSD Digital 6.
Anyone have any ideas what is going on here?
Mike
Old Jun 29, 2003 | 07:51 PM
blownbird01's Avatar
I had one do the same thing. Turns out, the shift light was bad. It was brand new.
Old Jun 29, 2003 | 10:30 PM
1Z2Z's Avatar
Bummer, that's alot of work to pull back out.
I sent a message to the Proform help email also. Can't wait for their reply.
Old Dec 3, 2003 | 06:18 PM
Eliminator's Avatar
How do you hook up the shift light where do the connections go to to get the reading??
Old Dec 3, 2003 | 06:21 PM
Black_Z28's Avatar
Hmm, so you're the guy that has BlackZ28 under CZ28.
Old Dec 3, 2003 | 07:29 PM
1Z2Z's Avatar
I returned the proform light and bought an MSD LED light and RPM switch. I had two Proform lights and neither one worked.
Hookup was to power source in fusebox, signal from Dig 6 , and ground under the dash. I don't recall where you hooked it up when not using MSD box.
Old Dec 3, 2003 | 07:38 PM
Brandon 95 Z28's Avatar
Hmm, my friend and I both have proform lights and they work great. Power and ground under the dash, tach signal from the correct wire on the back of the pcm.
Brandon
Old Dec 3, 2003 | 11:56 PM
1Z2Z's Avatar
Don't know what it was with the ones I had.
Proform tech guy said they have that problem sometimes.
I liked the adjustable limit feature rather than pills like MSD has, but got damn tired of rewiring the things.
Old Dec 4, 2003 | 07:51 PM
Eliminator's Avatar
So pretty much if you get on that works its easy to hook up.
Old Dec 4, 2003 | 08:07 PM
96 WS6's Avatar
Haha
Old Dec 5, 2003 | 09:24 AM
Eliminator's Avatar
yupper that would be me
The only thing is I cant make a link in my sig. I can link forums and anyother things but when I try to link my page in my sig. it just dont work.
Old Jan 8, 2004 | 08:02 PM
Eliminator's Avatar
Re: Help with Proform shift light?
Mike
The only part of the instructions that I can read is it states do not hook shift light up to MSD ignitions and only attach to tach terminal. I know this is a old thread
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
phantasm99
Aug 28, 2002 11:01 PM
Brady
Jul 29, 2002 10:30 PM
